Thread: 4l60e over drive issue???
    Just installed the transmission and now I'm taking it out for a test drive.
    This is in a 94 Suburban. I noticed that the rpm's would not drop much once I get going. Example, while driving on i75 at around 65 mph the rpm's were around 2300 to 2400 rpm. When I apply the brakes slightly the rpm's would go increase about 200. Tires size is 265/70/17(i believe) with a 3.42 rear, not sure if this helps.
    I did install a transgo hd2 shift kit, not sure if I missed a step. I'm planning on dropping the pan and remove the valvebody. Maybe the valvebody gasket shifted on me when putting it back together. BTW, with the shift kit installed, I thought it would shift faster and a little firmer. At this time, it seems close to stock.
    What do you thing I should check out.
    Thanks
    <div class='quotetop'>QUOTE(94burban &#064; Mar 24 2007, 12&#58;35 AM) [snapback]87167[/snapback]</div>
    Just installed the transmission and now I&#39;m taking it out for a test drive.
    This is in a 94 Suburban. I noticed that the rpm&#39;s would not drop much once I get going. Example, while driving on i75 at around 65 mph the rpm&#39;s were around 2300 to 2400 rpm. When I apply the brakes slightly the rpm&#39;s would go increase about 200. Tires size is 265/70/17(i believe) with a 3.42 rear, not sure if this helps.
    I did install a transgo hd2 shift kit, not sure if I missed a step. I&#39;m planning on dropping the pan and remove the valvebody. Maybe the valvebody gasket shifted on me when putting it back together. BTW, with the shift kit installed, I thought it would shift faster and a little firmer. At this time, it seems close to stock.
    Thanks
    Yeah, with a 3.42 and 265/70/17&#39;s, you should not be at 2400 at 65 mph. Do you even feel it shift into 4th (OD)? If not, drop the pan and re-inspect everything. Re-read the instructions to see if you missed a step like you were talking about.
    It sounds like it isn&#39;t even shifting into OD...
    <div class='quotetop'>QUOTE(txarkitekt &#064; Mar 26 2007, 12&#58;33 PM) [snapback]87324[/snapback]</div>
    My problem was within the valve body, I installed the 3-4 relay valve into the body the wrong way.
    Found someone with this same issue on the LS1Tech forum..
    Thanks...
    Mar 2006
    Your rpm,s are going to jump some when you touch thr brake....this is unlocking your converter...so that part is functioning right. Now about the rpm&#39;s, I have a 275/60/17 and at 63mph I am taching around 1500 in od with 3.42 gears....I dont think you said how fast you were going so maybe you can compare to that....hope this helped
    Jarrod
