Is anyone using an electric water pump on there truck? How many horses have yall seen it save? Does it flow the water faster through the motor then the manual one? Any input is appreciated.
2004 EXC Silverado 6.2L
Mods:
I called a number of companies a couple of days ago and apparently no one makes one for our trucks. Or mine at least. I called Meziere, Moroso, and about 3 others. No luck. I'd like to know if someone knows different.
well you have the same motor design as i do. So i guess you and i are in the same boat.
Mods:
