Results 1 to 8 of 8
Thread: TB stall just installed
    Jul 2006
    College Station, TX
    I just install the trail blazer stall last night and i was wondering what needs to be done tune wise? It did lower my idle when holding the brake with the truck in drive. I now get a lope when i sit at a light. Is this normal? I think we may need to reconfigure a couple shift points.
    2004 EXC Silverado 6.2L
    Mods:
    How does the stall work? I have yet to install mine.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Jul 2006
    College Station, TX
    I love it already. But it does take a little getting use to because it is loose feeling.
    Mods:
    Jan 2006
    <div class='quotetop'>QUOTE(shwarmy &#064; Feb 28 2007, 10&#58;34 AM) [snapback]84764[/snapback]</div>
    FINE TUNE AND SHIFT POINTS, THAT SHOULD BE IT. HOW MUCH CAN YOU BRAKE STALL IT UP TO?
    ARE YOU GOING TO BAYTOWN THIS FRIDAY? I AM LEAVING ABOUT 4:30P.M.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jul 2006
    College Station, TX
    I can brake stall up to 2400 RPMS.
    Mods:
    Jan 2006
    <div class='quotetop'>QUOTE(shwarmy &#064; Feb 28 2007, 02&#58;52 PM) [snapback]84769[/snapback]</div>
    SWEET&#33;
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jul 2006
    College Station, TX
    I might be able to get a little higher when i get better tires.
    Mods:
    Jan 2005
    Humble/Houston TX
    it will feel stock within the next week. now get some tires on there and cut some 1.8 60&#39; times
    old mod list: H/C/I/N/E/G 408
