Thread: F.S. 05 6.0L heads and manifolds & more
    Nov 2005
    FOR SALE
    2005 6.0L 317 heads w/ 9000 mls...................$350
    2005 6.0L manifolds non EGR ........................SOLD
    2005 6.0L intake manifold w/ fuel rails and injectors......SOLD
    <div class='quotetop'>QUOTE(BEATERTRUCK &#064; Jan 29 2007, 11&#58;32 AM) [snapback]81567[/snapback]</div>
    FOR SALE
    2005 6.0L 317 heads w/ 9000 mls...................&#036;350
    2005 6.0L manifolds non EGR ........................&#036;50
    2005 6.0L intake manifold w/ fuel rails and injectors.....NO TB......&#036;60
    SOON TO COME!!!!
    Oct 2005
    drinking your alcohol
    any hp gains with the intake and heads swapped to a 5.3??
    DamnYankee: my nana failed
    sprayed99 Guest
    no you will actually drop your compression ratio down. since your running N/A there will be no benefits
    Nov 2005
    Just like sprayed 99 said. No gains. The 317 head does flow like a LS6 head BUT has 72cc chambers. Which makes good for a F.I. car, but not N/A.
    I do have a set 2000 LS1 heads which will give you some gains. You would be going from 62cc to 64cc, but you will pick up power from the biger vavles and the flow........... &#036;150
    SOON TO COME!!!!
