Results 1 to 10 of 18
Thread: Question for Allen?
    Jul 2006
    College Station, TX
    Since you last tuned my truck for 93 oct I have put the 160 thermo on it. I told you when you tuned it that i was going to be putting it on there. Should the computer already learn that there is a 160 thermo or can i bring it back to you to get it tuned a little more?
    2004 EXC Silverado 6.2L
    Mods:
    Jan 2006
    <div class='quotetop'>QUOTE(shwarmy &#064; Oct 12 2006, 08&#58;47 AM) [snapback]69020[/snapback]</div>
    IT SHOULDN&#39;T EFFECT IT. ASK IF THE S/D TUNE WOULD WORK BETTER? I WILL CALL YOU FRIDAY.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jul 2006
    College Station, TX
    what is the S/D tune?
    Mods:
    Sometimes the 160stat makes the truck run a tad richer, but it will be ok.
    If you have fans and the pcm was setup for the stock stat, you&#39;ll see the temp needle go up to 190 or so in traffice and come down as you start moving. We&#39;ll need to adjust that.
    allen
    Jan 2006
    <div class='quotetop'>QUOTE(shwarmy &#064; Oct 12 2006, 08&#58;54 AM) [snapback]69024[/snapback]</div>
    ITS A SPEED DENSITY TUNE. THAT IS ALL I KNOW? WE ARE GOING TO RUN ONE ON MY TRUCK WHEN I GET THE CAM/SPRING/HARDENED PUSRODS, STALL AND METH KIT IN NEXT WEEK. I THINK IT IS A MORE PRECISION TUNE?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    <div class='quotetop'>QUOTE(Jamest &#064; Oct 12 2006, 09&#58;17 AM) [snapback]69034[/snapback]</div>
    JAMEST
    Only for boost, not NA
    Gone, but not forgotten!
    Jan 2006
    <div class='quotetop'>QUOTE(SCIV &#064; Oct 12 2006, 12&#58;36 PM) [snapback]69052[/snapback]</div>
    SORRY? I&#39;M SO CONFUSED? SORRY SHWARMY.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    <div class='quotetop'>QUOTE(Jamest &#064; Oct 12 2006, 02&#58;59 PM) [snapback]69075[/snapback]</div>
    JAMEST
    We actually 1bar tuned that 408 stroker GTO and others because the engine was a little to radical for the maf, so yes, you can do 1bar tuning, sd mode.
    allen
    Jul 2006
    College Station, TX
    What would it take for you to order me a cam and the accessories also I would like to come up on a day during the week and have it done? Could this be done in a day for the cam to be installed and then dyno tuned for it?
    Also under a light foot would a cam hurt my gas milleage or make it better?
    Mods:
    Jun 2005
    Round Rock
    I wonder if a SD tune would work better on mine..... Still dies when in reverse.....
    08 HHR SS
