Results 1 to 10 of 11
Thread: Stupid Question
    May 2006
    Waco TX
    OK, to some of you guys this may be stupid, but remember my specialty is paint and body work, not so much tranny and stuff. Anyway. Where are you gears? Are they all in the rearend? So when you upgrade your gears is the only thing you have to change in the rear end? Or is there stuff in the tranny too? Sorry for the Stupidity.
    Mar 2006
    Dawson Springs KY
    When you see someone talking about a gear swap, they are talking about changing the ring and pinion gears that are inside the rear end.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    May 2006
    Waco TX
    <div class='quotetop'>QUOTE(KY_BOB &#064; Aug 3 2006, 01&#58;03 PM) [snapback]59833[/snapback]</div>
    so you could go from say 3.73s to 4.10s just by messing with the rearend.
    Mar 2006
    Dawson Springs KY
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Aug 3 2006, 01&#58;10 PM) [snapback]59835[/snapback]</div>
    I just noticed that you were AWD. The answer is "yes" for a 4x2 but on a AWD or 4x4 the gears have to be changed in the front differential also.
    May 2006
    Waco TX
    Well I already have 4.10&#39;s. Its for my friends truck that we are swaping a 6.0 in it. It has factory 3.23&#39;s. And it is 2wd. So you were on the right track. Sorry I didnt clarify
    Mar 2006
    Dawson Springs KY
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Aug 3 2006, 01&#58;27 PM) [snapback]59838[/snapback]</div>
    If that&#39;s the case, yes he just needs a set of rear gears and to have them installed but that is a great time to upgrade to a aftermarket differential, such as a Eaton or Detroit Truetrac. There would be no additional labor, only the cost of the unit.
    The reason that I mention that is that I had mine re-geared and used the stock G80 locker. About 6 months later I destroyed the G80. When it came apart, it damaged my new gears. I had to pay to have new gears and a new carrier/posi unit installed for a second time.
    DBYRD Guest
    <div class='quotetop'>QUOTE(KY_BOB &#064; Aug 3 2006, 01&#58;48 PM) [snapback]59840[/snapback]</div>
    any idea how much they&#39;d cost?
    Mar 2006
    Dawson Springs KY
    A new set of gears and a install kit should be &#036;200-250. The going rate around here for an install is &#036;250-300. A detroit Truetrac would add &#036;375-400 to the total cost.
    Apr 2005
    belton, tx
    <div class='quotetop'>QUOTE(Allstar55566 &#064; Aug 3 2006, 02&#58;30 PM) [snapback]59845[/snapback]</div>
    Next, his broke ass will be bitchin about gas mileage. :flipoff:
    Only cuz I know ya&#39; playa.
    2013 2wd Z71 6.2 crew cab
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(KY_BOB &#064; Aug 3 2006, 02&#58;48 PM) [snapback]59840[/snapback]</div>
    that damn g-80 took out my gears too when it blew, cost me 850&#036;
