Results 1 to 10 of 18
Thread: 640hp at 6psi in a TA
    Nov 2005
    Hey guys I know its a TA. BUT DAMN.
    They are still tuning on the TA we built a 408 for but, its allready up to 640hp at 5/6psi. They had to get out of it because it started runing lean. We will be installing some 60lb inj. The car is set up to run 14psi .
    I should be abel to get a video clip up soon.
    <div class='quotetop'>QUOTE(BEATERTRUCK &#064; Jan 25 2006, 10&#58;43 AM) [snapback]42186[/snapback]</div>
    Here&#39;s a pic of the car.
    SOON TO COME!!!!
    Nov 2005
    UPDATE: Pulled it a little higher ran 670hp at 6psi
    SOON TO COME!!!!
    Nov 2005
    ohio
    that car makes me
    Aug 2004
    Magnolia, TX
    <div class='quotetop'>QUOTE(Tim Z &#064; Jan 25 2006, 03&#58;36 PM) [snapback]42221[/snapback]</div>
    that car makes me
    yo tambien, we need a smilie for nuttin&#39; on the computer screen
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(2k5Squirrel &#064; Jan 25 2006, 04&#58;48 PM) [snapback]42226[/snapback]</div>
    skeet skeet skeet&#33;&#33;&#33;
    Post up a dyno graph, that&#39;s some great power&#33;
    Nov 2005
    I will Allen.
    And guys this motor is just a 402 sorry not a 408. It does have a stroker kit, stock 6.0l heads(&#036;550 new), stock rocker arms, headers,stock intake, Shaner TB and a cam. I can build this same set up for anybody.
    I will get a video clip and dyno sheets mon. or so. The 60lb inj. won&#39;t be here till mon. We were going to run it up to 14psi but, the GT-70 is only suposed to suport 750hp. Soooo we may only run it up to about 10psi till we get the GT-70 upgraded to a GT-76. Which should suport 1050hp.
    NEXT IS STSSILVERODO
    SOON TO COME!!!!
    Apr 2005
    belton, tx
    THAT&#39;S WHAT I&#39;M TALKIN ABOUT&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33; &#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33; &#33;&#33;&#33;&#33;&#33;&#33;
    2013 2wd Z71 6.2 crew cab
    Apr 2005
    I would say "WOW", but that&#39;d be a stupid understatement&#33;&#33; GREAT JOB&#33;&#33;&#33; Care to share a list of components and ballpark cost?
    93 Ext Cab w/ 99&#39; LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    Jun 2004
    george west texas
    damn thats some good numbers for not being tuned all out&#33;&#33;&#33;
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
