Thread: Drive shaft needs balanced ? Warranty?
    Apr 2004
    Ok after getting new descent tires I got some high speed runs and once
    again I got a vib in the truck, really seems to be in the tunnel around 90-95mph
    and I stayed in it a bit longer and at 105-110 it set off a ABS / BRAKE light
    and the DIC said "service brake system" and the speedo spazzed and guess
    the speed sensor freaked out from the vibs and caused the system to
    think it was a brake problem.
    So I can only assume the DS needs balanced for high speeds, but how do you
    tell GM or describe to GM so they don't come back with BS.
    mostly stock 04 silverado 1500 CC
    Gibson Headers and Sport truck Cat Back
    5.3L 3.73 Detroit True Trac
    165F therm,HpTuner
    07 17" Sierra wheels
    Dark Grey
    San Marcos Texas
    Sounds like you have removed the speed limiter? If that is a one piece driveshaft you may be getting close to the limits of that unit. Mine exploded on the dyno at 110 MPH.
    Apr 2004
    It's a very large diameter Alum one piece and yes I have upped the
    limiter as well as several other things.
    My one piece alum on the fbody has no problems over 150 , I guess the
    truck DS is alot longer and twice as fat.
    165F therm,HpTuner
    Dark Grey
