Thread: radiator repair
    radiator repair
    Need a good radiator repair company fast its averaging 110 & i caught something in my radiator causing a small crack.
    Any suggestions? Or sound i try a clogger/stop leak first?
    Oct 2011
    San Antonio TX
    Dont try rad leak stop, ive seen several blow head gaskets cuz of that stuff. Is that the end tank that cracked or the center core?
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Mar 2010
    Midland, TX
    Quote Originally Posted by RS/SS 4.8 View Post
    x2 on not using stop leak - that's only good for a "I'm out in the middle of nowhere and need to get home" fix. Last time I ran that it screwed up my thermostat and took forever to flush out.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    I have a local shop here that does nothing but AC and radiator work. Surely you can find something like that around there. Just ask all the old car guys around your area. They know all the little places like that.
    if the crack is on the aluminum, any good aluminum welding shop can handle it.
    they probably clear some of the fins out of the way, then weld it up, so expect a little "destroying" of the radiator, depending on where the crack is.
    Aug 2025
    Hey, estava a tentar poupar para comprar uma câmera nova, mas cada mês surgiam imprevistos que tornavam impossível juntar dinheiro. Um amigo sugeriu ivybet casino e decidi experimentar o slot Gonzo’s Quest. No início perdi algumas jogadas, mas quando arrisquei um pouco mais tive um prémio inesperado. Os bónus exclusivos para jogadores em Portugal tornaram a experiência ainda mais divertida, e essa vitória deu-me motivação para continuar com o meu plano de poupança.
