Results 1 to 10 of 11
Thread: 4l80E trans fittings
    Hey Guys,
    Does anyone know what size the trans fittings are for the 80e?
    I don't want to use the stock metal tubing and clip. I'd rather change out the fitting and use some different line, but that requires me changing the brass fitting out.
    I'm not sure what size the brass threads are, does anyone?
    thanks,
    allen
    Jun 2005
    What I would do I download the DANA/WeatherHead Catalog with all their fitting listings in it. If you look under "Special Adapters" you can find a few fittings that say transmission coolant adapters, they may or may not work for you, but they have pics and thread descriptions of every fitting. In the catalog that I have "Special adapters" starts around page 125.
    Conrad
    Oh, and you can get/order the WeatherHead parts at your local NAPA.
    “Learn as if you were going to live forever; Live as if you were going to die tomorrow.”
    “In dating and mating, what is finally settled for is always a function of what is available.”
    http://img.photobucket.com/albums/v7.../Signature.jpg
    Jun 2003
    hey didnt i bring you as fitting??
    formerly 02denali 12.79@107
    Thank for the info guys, I'll check it out.
    not sure lance, can you find out where you got those from?
    thanks
    allen
    Conrad
    I searched all over dana.com and can't find the catalog, would you happen to have a link?
    thanks,
    allen
    Jun 2005
    Aug 2005
    Is it like an NPT fitting going into a compression fitting or somekind of lock fitting? That would be my guess.
    2000 chevy SCLB: Pacesetter Longtubes, Nelson Tune, Dual Dynomax Bullets, Ram Air, Power Aid TB spacer.</span>
    <span style=\'color:red\'>Daddy heard the lope and made me pull the lunati custom grind so..... time for the Z06 cam.....he cant here that one.
    Jun 2005
    Hey Allen you end up finding the fitting that you needed?
    Conrad
    Conrad
    not yet, but i&#39;ll eventually find it.
    thanks,
    allen
    Jun 2003
    i would need another fitting. what i did was take it to hydraulic supply store and had them match up a fitting. if i had another fitting i could do it again. im sure they would give them to me. got a fitting you can send me with a nelson performance decal.
