95 rcsb swapped 2001 4.8. Cel came on couple weeks ago, so I finally took it to the parts store to pull the codes.
Maf, knock sen bank 1 and 2.
Maf is only a month or two old, so it will be replaced with warranty
The scan tool said that both knock sensor codes are "pending" wtf does that mean. Also, could it be my dumped manifolds causing it to pick up knock.
Could this cause the little 4.8 to fall on its face after 3k rpm,.
