Thread: A/C and Alt brackets from a Duramax
    I noticed that the Duramax engines have the A/C and Alternators positioned on the same sides as the 96-00 obs. I was wondering if anyone had tested to see if these bolt in or could be made to work with an LS engine. I'm looking at trying to keep my stock compressor and alternator in the same positions and everything I have found uses either a R4 compressor, or a Sanden 508.
    Jan 2014
    Las Cruces NM
    Get in touch with Lextech. He has a really good kit that does just what you want. I'll see if I can find the thread.
    Here you go
    http://www.ls1truck.com/forums/lsx-t...acket-kit.html
    Sep 2009
    NE Ohio
    Here is his thread.
    I plan on ordering mine later on this week from him.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    I have seen his bracket before and I'm going to attempt to make my own first, I was just curious if the duramax brackets would fit.
