I've looked and searched and thought I'd found the schematic I needed but according to PSI conversations the 94 is different gauge cluster wiring than the other square dash models. I've gotten all except the tachometer, coolant temp, and speedometer working. And obviously the PSI harness has the wires for them to but I can't find the correct wire under the dash. Can someone help? With all the knowledge floating around on this forum I know someone has the answer for these three gauges to work. The battery gauge works great along with the fuel gauge. I'm not sure what's happened to the others. Please?
