Results 1 to 10 of 10
Thread: Correct psi.
    Dec 2009
    DIrty south AZ
    Correct psi.
    Im going to be swapping the springs out with the heads on tomorrow i was just making sure what psi i nees to put into the cylinder to keep the valves from falling. Ive heard 90-100 psi? Wanto make sure before i mess anything up motors a 2004 5.3 lm7
    Dec 2009
    DIrty south AZ
    bump... anyone have an idea?
    Built 2 Run! 6XX HP/ 6XX TQ
    just use whatever, damn. Enough to hold the valves shut.
    I prefer to roll the engine over where the piston on that cylinder is up. Much less scary.
    Nov 2009
    SAN ANTONE
    100psi will be fine nothing will happen
    Anyone else want to bet they'll be another thread? What's wrong with my engine? I HEAR AIR LEAKING OUT!
    Dec 2009
    DIrty south AZ
    Ok cool thanks ray, and ya i think thats what im gunna do Justian, appricate the help and ideas.
    Oct 2011
    San Antonio TX
    Ha, tell me about it. I was so damn excited to put my cam in I forgot to put it tdc and with my small compressor and the leaking air, tank ran out pretty fast and dropped the valve. Got lucky and pulled it back up with a magnet.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Mar 2010
    Paris, TX
    Can be hard to get it to stay at TDC once aired up. Have had my compressor turn the crank and put the piston at BDC before. Also have had the valve stem seal catch a valve once before. Got lucky on that one. I just hook my air hose up to the cylinder and make sure my compressor is over 100psi.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Dec 2009
    DIrty south AZ
    what i ended up doing was installing the spark plug tool, and turning over the crank. it would eather push air out or draw air in. once it wouldnt do neather i would put 100 psi to it and it would hold. so far i have gotten the passangers side all swapped out. thanks for the help guys.
