Results 1 to 10 of 15
Thread: No Reverse
    Aug 2012
    Hibbing,MN
    No Reverse
    K I did an LQ4 swap and am using my stock 4L60E and I have no reverse. Have hooked up the Tech2 and found my PRNDL switch shows the gear change. But the Trans Fluid Pressure switch shows Park, Neutral, Neutral, Drive4, Drive3, Drive2, and Drive1. Could it be in the valve body when I did a rebuild? PLEASE SOMEONE HELP ME WITH THIS!!! I need my truck back!!! My GTP spun a rod bearing so I haven't had a car for the last couple weeks and am sick of F'n walking!!!
    any dtc's? that will let you know if you forgot to plug something in.
    maybe a torn gasket, leak, etc.
    after a rebuild, sometimes that reverse pin is the issue, had that happen before.
    if you can't find anything on the outside, just say ... and pull it back out and tear it down.
    Aug 2012
    Hibbing,MN
    no dtc's and i'm hopin it not a torn seal cuz i really don't wanna do any more removal then I already have
    it's only funny because i've been there, hahaha.
    it'll give you something to do over the weekend, oh boy what fun!
    Aug 2012
    Hibbing,MN
    I would work on it over the weekend but it's stuck in a stall at school... sucks!!! But i have excellent resources there Alldata, Mitchell, Tech2, all kinds of fun stuff like that. HPTuners only gets me so far for what I'm workin' on.
    Aug 2012
    Hibbing,MN
    K so i came across a deal for a 80E 10,000 miles or so with no converter. Tradin the GTP for it. For my basically stock set up would you suggest just a stock converter? or Would you get something from the aftermarket? I am tryin to go cheap.. Ideas...???
    A good 80e is gonna cost you $,1000, unless you find a used one in good condition, usually half that cost.
    Stock setup, might wanna use a stock converter if you're going for a budget install.
    Aug 2012
    Hibbing,MN
    Thanks for all the info farmtruc. But a converter question now, I'm lookin around online and have found GM81 and GM82 converters and have no idea what the differance between the 2 is. This will be the first I've really delt with torque converters, always had one for the 60E
    Edit: Found out with some research GM81 is low stall and GM82 is high stall no sur of the stall speed but I'll research that too
    The high stall part number isn't much higher but every little bit helps. I think one is around 1800 and the other 2100rpms if I Rememeber correctly. Been a long time since we bought one.
    Aug 2012
    Hibbing,MN
    Earlier I said "basically stock set up". My enigine is basically stock but I put som 806 heads on it. I've been wondering what my CR is with everything stock (gasket thickness, compression height, and no shave on the heads). Then I was wondering how they would affect my torque curve and about where they moved it to. I just graduated college for auto so i kinda feel like a dumbass askin all these questions but there is still alot I don't know.
    Sorry their 862 heads...
