Results 1 to 10 of 15
Thread: No power after swap! Horsepower that is.
    Jan 2007
    Lewisville,TX
    Guys I'm so frustrated with how this whole swap has gone, I literally hate this truck! Here's the details tell me what you think. Ideas on what to do. Thx
    4.8l with ls1 intake, 212/218 cam, long tubes, no cats 2.5 pipes to magnaflow mufflers, one of which I had on before the swap. Stock trans and converter with 90k and worked just fine before. Lots for ppl use this cam with stock converter and videos prove it sounds good, the lope i mean. Mine does not! It starts, runs/idles very good. Just doesn't sound like it has a cam??
    The PCM has been basically mail order tuned, vats off and given specs of my cam. At LG Motorsports, a local corvette tuning place. Will no dyno tune cause no power? I mean this truck will barely go up my driveway. I plan on taking it back to them but I have to drive it there and I'm scared. Lol.
    95 Chevy, bagged and bodied, LSx swap/detail in progress
    It should be a fairly stout setup, do you have any way to scan or datalog? Do the harness, pcm, and operating system match? Ive read where others ran into issues mixing car/truck parts.
    Jan 2007
    Lewisville,TX
    My Mcheck engine light is off and on. I used a code reader and only got code for gas tank something cuz of my fuel cell. Never did that before swap. Engine and PCM from same truck, PSI standalone harness.
    Have you pulled and read the plugs? Or can you tell if its dumping raw fuel out the pipes? Or maybe misfiring? I did a 5.3 swap a few years ago and that engine had been sitting long enough for the injectors to stick, it sputtered, popped, and fouled plugs, stuck a set of pullout injectors in and its smooth as glass.
    Just for reference, it was a 94 short bed, stock lm7 with tsp224r, stock 4l80e, stock converter, 3.42 gears and tune. No track times, but the one time I raced a buddies 2002 short bed 5.3l, tune, 4.10s, etc, it was a bloodbath, probably put 7-8 car lengths on him and we were spinning on the launch and had to let off.
    Jan 2007
    Lewisville,TX
    Yes I noticed some dark oily/fuel from the left header. Just pulled plugs and they don't look new, which they are. Left side looks worse than right too. I not a mechanic, but a good parts replacer. Injectors are used camaro stocks. Smells like raw fuel when running. Maybe they cranked the pressure up? If that's possible.
    Jan 2012
    warwick ny
    Make sure you have spark on each cylinder.
    What's your fuel delivery setup? I think ls1 fuel rails should be preset to 58 psi, at that psi ls1 car injectors should be 28 lb per hour. If your pcm is tuned for a truck it could be set at 24 lb per hour injectors making it rich. If you can I'd verify fuel pressure, check for misfires, and pull those injectors out and get them cleaned. You should be able to see the gunk on them if theyre blocked.
    Jan 2012
    DFW, TEXAS
    Quote Originally Posted by dimebagged View Post
    I bet that was pricey. was it a new cam? which springs and pushrods? Nelson performance is your answer
    Dec 2004
    San Antonio, TX Area
    Does the throttle body butterfly open up all the way? DBC or DBW?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Arizona/Utah
    Any exhaust leaks?
