LQ4 into '83 K2500, looking for suggestions.
Hello everyone, I've been reading and researching LS engines for several months now. I have a 2000 LQ4 with ~200k miles on it that was a running take out. I want a modern, powerful, efficient engine that I can put some miles on before it needs a rebuild (again).
Currently my truck has a 400 sbc, SM465, NP208, and 4.10 gears f/r. I also have an NV4500 & NP241 for it, to go in with the LQ4. I want to build this as a DD, so I'm trying to figure out how to squeeze some fuel economy out of an LQ4. With the gearing of the NV4500 I am also tempted to put 3.73s in my diffs, I have the early NV4500 with deep low gear. The truck doesn't tow or haul regularly, but if I need it to I don't want it to...well frankly, I don't want it to suck at it.
Also, my '83 is a one-family truck, my dad bought it the same month I was born...to say I am attached to it is an understatement. I grew up in this truck with my dad. It has close to 500,000 miles on it, the 400 sbc is the 6th or 7th engine (went through about 5 "Hecho en Mexico" rebuilds in the early 90s (my dad wasn't buying them)). The most major departure from stock modification I have done to it is remove the smog pump. It still has an egr, still has the heat riser after the passenger manifold, still has a quadrajet ('85/'86 model, elec choke, no b-s, no elec feedback garbage)...the plastic intake tube was cracked out really badly where it slips over the air cleaner pan intake so I went to the dealership about 8 years ago and was able to buy a new one. That all being said, with the LS swap and NV4500 upgrade I still want it to appear stock. Part of my inspiration comes from Holley's '67 Shop Truck. To maintain the stock appearance I would like to use a 4-bbl manifold, like the GMPP ones, a fuel injection throttle body (Holley & FAST are the first two that come to mind...), and either relocate the coils or cover them. Don't know about aftermarket EFI controllers so was thinking GM ECM. I won't have a MAF, which if I understand correctly is called speed density (correct me if wrong), can a GM ECM be tuned/setup for speed density or MAF-less system? Fuel delivery I was thinking having the manifold bosses drilled and an injector at the end of each runner (like the Holley build). I want my factory (tall) air cleaner to sit atop the LQ4.
My plans are (were) to tear my LQ4 down, have the major components checked out at a competent shop, new bearings, seals, etc everywhere. I need advice and/or recommendations for a fuel efficient build. I am leaning towards keeping my iron heads and port/gasket matching them to the manifold. Is there a more efficient cam over the stock truck cam, or an equally efficient one the offers more power/torque? Should I bump it up to LQ9ish compression, 10.0:1 from 9.4:1. I want it to be 87 octane friendly if possible, my 400 sbc pings on < 89/90 now and it's friggen expensive.
I am tired of turning almost 3,000rpm with an old carb'd sbc to go down the highway at 70mph. Am I off my rocker on what I'm trying to do? I know there is a lot of potential in tuning, just don't know where to start. Cam? Pistons? Rods? Heads & hardware? Injectors? A great big thank you to anyone who can help me out.
Books I have and have read cover to cover (multiple times): Motorbooks Workshop - How to Build and Modify GM LS-Series Engines by Joseph Potak and How to Rebuild GM LS-Series Engines by Chris Werner.
- You may not post replies
- You may not edit your posts
