shifter problem on 1998 Tahoe swap
Anyone that has done the swap on a truck with cable shifter ran into any problems?? I have a brand new cable from advance auto,, The shifting is stiff and if I pull the shifter all the way down to 1st gear and come back up into park I run into a snag, have to shut the engine off , crawl under and manually put the trans back into park....
I used dirty dingo mounts and had to notch the crossmember on the trans so that the mount would go into it ,, looks like my trans is a inch forward more than it originally was, I am using a 4l60 trans from a 02 silverado as well....
- You may not post replies
- You may not edit your posts
