Results 1 to 7 of 7
Thread: Weir t56 bell housing bolt up 2 a lsx motor?
    Sep 2009
    In my 86, I have a 78 block mated to an lt1 t56 using the wier hot rod products adapter kit. What is it gonna take to bolt this up to a 6.0? I've been told it would work but the top bolt wouldn't b used. Will this work, or is there a better way? I'm also concerned with how much horsepower that this tranny will hold. I'm looking at heads, cam, injectors and possibly even a turbo. This setup has less than 100 miles on it and is in a custom truck where the floor board has been built around the trans, so I really hate to change it out. I could possibly end up having any to rebuild the floor boards. Thoughts and opinions?
    Thanks
    Trey
    Sep 2009
    Can anyone tell me if I swap out the 350 with lt1 t56 for a 6.0 with ls1 t56, if the shifter will fall in or close to the same position? Will the floor board b the same shape or is there a big difference in shape with the two trans/bell housing?
    Thanks
    Trey
    Jan 2012
    DFW, TEXAS
    you'll be fine, just swap
    Mar 2012
    Colorado springs
    I just converted my lt1 t56 to a ls1 t56. Research dude, i read over a hundred pages in forums before starting the swap. I think the ls1 t56 shifter is farther back from what i could tell, the bellhousing was longer on the ls1 style(not much at all though). I'll see if i can find some stuff for ya.
    1999 silverado rcsb. 6.0L and. T-56, Hurst short throw, 4.11s, auburn limited slip, 3/4 drop, Nelson tuning, Texas Speed 233/239 .595"/.603" Camshaft, Kenwood everything, electric fans, custom made hood, custom tailgate, magnaflow 3 inch true duals, hooker headers, and too much money.
    Soon- wheels and tires, Ford 9 inch with 5.13 gears.
    Sep 2009
    Ok thanks. I tried searching but couldn't get it to work with the small letters (t56 lt1 ls1 etc). I'll keep looking around.
    Thanks
    Trey
    Mar 2012
    Colorado springs
    http://m.performancetrucks.net/forum...1877&styleid=4 this is what i used, over 100 pages and almost every one had something useful on it. Good luck with your swap. Feel free to pm me if you have any more questions.
    Mar 2012
    Colorado springs
    http://www.gmhightechperformance.com...n/viewall.html also used this same company. Just be prepared, the conversion cost about $700. Not the $400 they claim, because transmissions require things like bellhousings. Of which are not cheap!
