Results 1 to 7 of 7
Thread: Possibly killed my first 60e
    verona, virgina
    Well early Monday morning (around 3:30am) I got off work and went to go pickup my little one from my inlaws. On the way I think I did one wot pull Rollin into it after I got going from a stop light just to mess around. Well drove normal after that and stoped at a light and went to turn onto their road and the gov lock came apart...I put it in 4hi to ge me off the road and I had nothing in drive. I pushed it off the road and looked under it turned it off and on tried changing transfercase selections. Finally manually put it in first and I was able to go and had second also. So I picked her up and decided to limp it the 7ish miles home. Got up the road had manual first second and third but nothing at all in drive. Left it in 3rd when I came to a light and again wouldn't go from a stop but I have it if I manually shift to it while driving. I've got another rear for it lined up since it busted the housing when it went and once I get it in I can diagnose a little more but from my readings I may have broken the forward sprag. If I'm wrong please correct me or if anyone has any input that would be great. Looks like my tax return will go towards a built trans finally lol
    03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
    92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
    86 trans am: lm7 hot cam th350 3500 stall
    Jul 2010
    Douglasville Ga
    You did some good research. It is without a doubt the input (forward) sprag. In M1&M2 the the overrun clutch is applied which bypasses the sprag and provides engine braking. In D3, the overruns are not applied until it reaches 3rd gear. Sorry for your luck bud. I just had to build the Trans in my cummins so I feel your pain, lol. Spent $2500+ all parts!
    verona, virgina
    Yes was debating on a local build or ordering a flt or performabuilt trans. Either way ill be in about 2k -__-. And I was hoping to buy a t56 for my swaped car this year too ugh lol
    Jul 2010
    Douglasville Ga
    I really hate to be a solicitating vulture but... http://www.performancetrucks.net/for...l-lvl7-509138/ I have a couple pms on it but no one has pulled the trigger yet.
    verona, virgina
    I'm 4x4.
    Oct 2011
    San Antonio TX
    Have him swap the output shaft.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    verona, virgina
    Going to be a few months before I can get a trans back in it. As long as my overtime keeps up that is.
