Results 1 to 10 of 12
Thread: Headers or Tune
    Apr 2005
    I just installed a CORSA cat-back exhaust system. I am not getting the performance I expected. I have been told that I do not have enough back pressure. What are my options?? Nelson Tune or Headers.
    2002 Suburban 5.3L, K&N Intake, Gran. MAF, Powerstat, Baer AlumaSport Brakes, Russell Stainless Brake lines, Mild Belltech Lowering, Belltech front lowering shackles, 20's Goodyear GTII's, 4.10 gears, Servo, TB Spacer, Hypertech Tuning, Corsa Cat-Back Exhaust system
    Jan 2005
    Conway, AR
    The Nelson tune will help alot! Headers will also greatly improve your backpressure as you are scavenging more exhuast gases out of each cylinder. Long tube headers will be your best bet. ASM, TOG, Thorley make good sets of long tubes. If I had the choice I would choose the Nelson tune though.
    Chris
    Apr 2005
    Thanks Chris. I have a Hypertech Tune right now but considering the Nelson tune if it gives me the added performance. I am weighing my options. Nelson tune and headers are about the same price if I go with shorties
    Apr 2005
    Saint John, MO
    Chris
    Not knowing your $$$ situation, if can't get both right now, go w/ the Nelson tune. Not knocking shortys, lots of guys say they like them, but i'd save up the extra $$$ for long tubes. LTs will be mucho benefit if you decide to go w/ a cam upgrade later on.
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
    Apr 2005
    Thanks for the advice. I cannot go all out just yet with the headers and the new tune. If I can sell my HYPERTECH on ebay for some much needed cash maybe I can do both. What kind of price are we looking at with the long tube headers?? Do they bolt right up or do I need to do some mods? I know I am working on a big heavy vehicle but I would like to make it quicker naturally. Again thanks for any help.
    Jan 2005
    Conway, AR
    Long tubes will require some cutting of the exhaust pipe, not sure how much as I havent done this before, but I know some modding is necessary.
    Chris
    Sep 2004
    Not enough back pressure is a myth. The ideal situation would be to have no back pressure. Where this gets a little trick is the headers. If the primary tubes on the headers are to large the exhaust pulses do not create a vacuum behind them to promote scavenging. So...If the primaries on your headers must be the correct diameter so that a vacuum is created, but no back pressure in front of the exhaust pulse.
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    Jun 2004
    West side of Houston, Spring Branch
    The tune is the way to go. Dont buy the shorty headers, you will be dissapointed in performance. I know this because I had the edelbrock shorties on my last truck. With the tune and cat back the truck will run good. If you want better performance get the hot tune and run premium fuel. Allan says the hot tune is good for about 40 more HP. Best bargain around.
    Once you do this it will run good enough until the cash situation is better and you can get the long tubes.
    Oh yea, if you want performance dont complain about buying premium fuel.
    going fast = money spent
    2005 ECSB 5.3
    Jul 2005
    what about losing torque when adding headers? i was under the impression that there was an amount of backpressure necessary, otherwise low-end power will suffer.
    i too was interested in adding a set of headers, but concerned about raising the torque peak.
    Jan 2005
    Conway, AR
    Adding long tube headers will give you a good deal amount of torque more.
    Chris
