Results 1 to 7 of 7
Thread: 408.Luke's Silverado SS for sale
Threaded View
    Houston
    Posting my 2003 SS Silverado for sale again, it had been in some long-term negotiations that have fallen through. I need to sell since I’m back in school and just can’t afford it.
    A few quick things about the truck, I have only been to the track in it once and ran ~12.4 at 129.7 on a 350 shot w/ lots of traction problems. I just put new tires on it (M&H 390/45/15’s) and will have the drivability tune ironed out by the time it sells; WOT tune is good. I had the trans rebuilt in April/May after blowing it up on the street at TX2K12. This was caused from the tune and has since been fixed. I had the Circle D converter re-stalled in June/July to a “2800”, but its more like a 3200. I was blowing through the converter so we made it as tight as it would go. The truck cruises great and I would be using it as a daily if there were more E-85 stations in Austin.
    There will be NO nitrous tune, there are to many variables on a 350hp E-85 shot to feel safe selling it with a nitrous tune. Note the “motor” tune is the tune that I use for nitrous, so here is what I mean about no nitrous tune. There will be no pills in the system, the nitrous fuel PSI wont be set (I have a low PSI system) and the Lingenfelter timing box will be maxed out. I use the timing box so I can have full timing when N/A then when the nitrous activates it pulls the proper timing. So everything is there, you will just need to figure out what pills you need and set PSI/Timing accordingly
    If the truck is bought locally we can work something out for DBRods to do the nitrous tuning on the truck.
    Price: $32,000 or best offer
    This is the price that the previous buyer and I were talking about so it’s a good place to start. I don’t mind offers just send me an E-mail; please don’t contact me asking what my low is, I don’t know myself what it is and would rather consider/counter an offer.
    Would be willing to sell my 20ft car hauler along with the truck. The truck fits perfect on it.
    Contact: Please E-mail me at luketrueheart13@hotmail.com I will give my phone number out to any interested buyers. Also try not to PM me because I usually don’t check to see if I have any. Please feel free to email me with any questons.
    Location/Delivery: The truck is located in the Austin Texas area, but I travel a lot through Central/South/South-East/East Texas so I can easily get it to those areas fast. I have a truck and trailer and I’m willing to deliver it anywhere in the lower 48 States or maybe even Canada. I do have school and have to work around that so depending on where you are it may take a while. (have to wait till Christmas/Spring break/Summer break).
    2SOONJR plates are not included
    The Truck:
    Engine:
    HKE Built 408 stroker in the original iron 6.0 block
    Build list
    - Callies C-Series 4.000” stroke crankshaft
    - Eagle LS1 H-Beam Rods 6.125” length
    - Wiseco 4.030 Bore K464X3 3cc Pistons
    - Wiseco GFX piston Ring set. Gapped for ~300 shot
    - ACL Main and and Rod bearings
    - ARP Main and Head Studs
    - L92 heads with HKE “econo” port
    - .650 Lift springs w/ TI retainers
    - 3/8” pushrods
    - LS9 head gaskets
    - EPS custom spec. cam for Big shot, L92’s and Vic Jr.
    Nitrous/Intake setup:
    - Edelbrock L92 Vic Jr. port matched and Ported.
    - Direct Port plumbed by DB Rods, Dual solenoid setup 600HP shot capable
    - DBRods elbow
    - Nick Williams 102MM DBW throttle body w/ 4 ½” intake tube
    - Lingenfelter LNC-2000 timing box
    - NOS window switch, 2 stage nitrous controller
    - 2 10lb nitrous outlet bottles
    - All -6 nitrous lines
    - Stand alone fuel cell in OE battery location w/ pump and regulator (low psi)
    - Weather pack connector for easy intake removal
    Transmission:
    - 4L80e stage 3 (and then some) built by Mike Kurtz (Century Auto and Trans)
    - Circle D triple disk stall converter
    - I can get full trans specs if anyone is interested; I think the only thing that is original is the case.
    - 40,000 GVW trans cooler
    - Deep TCI pan
    - No trans brake
    - RWD converted
    Rearend:
    - Moser Fab 9”
    - 35 Spline axles
    - Spool
    - 4.10 Gears
    - Driveshaft Specialist Inc. 2 Piece steel drive shaft
    Suspension:
    - DBRods 4 linked rear w/ Strange Coilovers
    - Strange Coilovers up front w/ custom mounting since the Ride Tech kit wont bolt up to 4x4 trucks
    - Custom Tubular lower control arms
    Fuel System:
    - DBRods aluminum fuel cell
    - Areomotive A1000
    - Pre and Post filters (pre-100 micron, post-40 micron for E-85)
    - -10 line through pump and filters, -8 line to rails, -8 line return
    - Edelbrock Fuel rails
    - 63lb injectors
    - Stock sending unit for fuel level
    - Fuel PSI gauge through areoforce gauge
    Exhaust:
    - DBRods Custom 2” primary – 3 ½” collector headers
    - DBRods Custom 3” exhaust w/ X-pipe
    - 2 magnaflow mufflers
    - Exhaust is turned down and dumped before rear axle
    Body:
    - Just under 130,000 on the body
    - 5 lug conversion (5 x 4.75 Vette/Chevy pattern)
    - Battery relocated to under rear of bed
    - Gauge Cluster has been replaced
    - Autometer wideband
    - Autometer Nitrous PSI gauge
    - Areoforce gauge w/ aux fuel and oil PSI gauges
    - SoCal Diesel Gauge pod
    - Nitrous bottles mounted in rear seating area
    - Rear seats and interior pieces are removed but all come with the truck except rear seat belts are missing
    - New bed liner
    - Recently Detailed
    - 18” ZR1 replicas, front and rear w/ spacers
    - 15” jegs 5 star wheels for the rear, when work needs to be done.
    Again if there are any questions please feel free to E-mail me, and now for pictures
    Intake and elbow
    Intake and elbow
    Engine bay
    Front suspension (w/ stock lower control arms, now has tubular)
    Rear suspension and fuel cell
    Nitrous controller/relays
    Battery Jumper posts
    Stand Alone cell
    DBRods Headers
    Century 80e
    Interior
    Interior
    New bed liner
    On the trailer
