Thread: 4.8 Pistons
    Mar 2010
    Paris
    4.8 Pistons
    Does anybody have a set of pull out 4.8 pistons for sale or ls7 lifters? Lifter tick is getting worse by the mile, and if I'm gonna go thru trouble to change the lifters, may as well pull the motor and freshen it up since it has 180k on it. I'd like to swap in some 4.8 pistons while I'm at it also.
    Truck: 05 GMC CCSB SLT Z71,
    Go Faster: 5.3, 219/227 .607/.614 112, milled heads, eBay CAI, Circle D 2800, 3030 Built 60E, E-Fans, 3030 Tuned, LT's, Spintech Muffler, DuraGrip w/ 3.73's
    Look Better: 10K HID's lows & fogs, tinted Chevy tails
    Arizona/Utah
    I would say with 180k miles the bottom end is just getting broken in, but if you are set on doing it the 4.8 flat tips is a great way to raise the compression. Should be fun good luck.
    Do a cam springs and hardened pushrods etc while your at it.
    Mar 2010
    Paris
    I've got a cam and pushrods already. Need springs. I know that 180k is just broken in but I'd like a little more compression, and there really isn't a reputable machine shop around here to shave the heads.
    Sep 2010
    How about milling your heads or some 243's. I'd rather do that then take out, take apart, and rebuild the bottom end.
    A few months ago I took out a 5.3 out of a Yukon XL that had 120K on it and it was amazing how little wear there was. I was actually mad I took it apart.
    @J_Industries ON INSTGRAM
    TURBO MIC PERFORMANCE
    MAZZULLA OFF-ROAD
    KING SHOCKS
    [HOONIGAN]
