Results 1 to 5 of 5
Thread: Finally got to start my conversion
    Finally got to fire it up. I have lots of cleanup work and install the shifter and some wiring to button up. Gonna build my cold air pipe this weekend 4" alum pipe with ls7 MAS. Hope to get all that done this weekend and get it out of my shop for a ride. For the details...
    1991 c1500 4.3l v6 5 speed rcsb
    forged ls7 bottom end
    Tea stage 2.5 ls3 heads that Brian Tooley cleaned up
    Ported ls3 intake
    stage 2 4l80e
    nelson harness
    lots of other goodies...
    Cant wait to sort the tune out and bring the idle down. enjoy
    http://www.youtube.com/watch?v=WwyHt...&feature=g-upl
    91 RCSB-- Forged LS7 bottom end, ported LS3 heads, ported LS3 intake, custom EPS cam and a 4l80e.
    Nov 2010
    Coldspring, TX.
    Cool beans! Got to start mine up over the weekend for the first time as well. I too have a high idle and SES. Gonna hook it up to the scanner tonight and start debugging. Post up what you find out with your high idle - may be the same issue on mine.
    Current project.
    1957 Belair
    SOLD!
    http://www.ls1truck.com/forums/my-ga...rkwhite61.html
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    thanks!
    I figure my idle is a combination of factors, tune, no maf , ... Plus I just cracked the TB to get it to run. I will still need to drill by TB to bring my IAC values into check. That will help too.
    Too keep some tech in the thread. The couple of items I haven't solved yet are as follows...
    1. gonna swap to the 3 wire temp sensor / sendor and do away with the S&P temp adaptor on the pass side.
    2. gotta get the speedo and cruise working. guessing I will have to go with the dakota digital speedo conditioner
    3. get rid of the check engine light on dash. will probably just pull the bulb. \
    4. I have a ss454 cluster out of a 90 model ( moonies ) to swap in
    5. mount my tach, and wire up my fuel pressure and wide band guages.
    6. swap to 3" drop springs in the front because it sits about an inch higher now on the same 2" drop springs as with the 4.3 v6
    What are the specs on the cam?
    Its around 236-248 114+2 .62's lift
