Results 1 to 7 of 7
Thread: Spark plugs
    Jan 2012
    Baytown, Tx
    Spark plugs
    As he title says, what spark plugs is everyone using? I had the NGK iridiumIX pn-tr5ix or 7397 in 5.3. The plugs I just replaced are NGK V Power pn-tr55 or 3951 that had 3500 miles one them. I went with the same plug but should I have gone with he iridium plugs? Which one is better?
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    1967 Chevy II 5.3 w/ 76mm snail
    casey23 Guest
    I use NGK tr6. 18.00 for a set of 8. Look up plugs for 2002 Camaro SS 5.7
    Quote Originally Posted by casey23 View Post
    Thats the plugs I use in mine.
    Jan 2012
    Baytown, Tx
    I think I will run these plugs for awhile longer and then get the iridium plugs later. I imagine the v-power plugs are almost oem style plugs. Whats the diffrence from tr55- tr6?
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    Jan 2012
    DFW, TEXAS
    Quote Originally Posted by N/ALS1 View Post
    i believe heat range, (someone correct me if im wrong), tr6 is a colder plug. tr55 for n/a tr6 for boost?
    Quote Originally Posted by blacstar View Post
    Yes heat range. And yes tr6's are a colder heat range. But no not tr55 for NA and tr6 for boost. I'm NA and run tr6. It's all about what your tuner thinks. My tuner recommended tr6 for what I've got and the tune I have. It could be different for every single truck here.
    Jan 2012
    Baytown, Tx
    He put in tr55 but after 3500 miles you can see my plugs look a little crazy. Ill post a link of my other thread that has pics of the plugs and the problem I had cuz of them. Im going to get with him and see what he says about the iridium ix plugs.
    http://www.ls1truck.com/forums/power...3525-help.html
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
