where or what do you guys think is wrong with it?
2002 Maro ls1 130k miles....it smokes a lil and i noticed steamy water bubbling around exhaust ports...
anyways im pulling motor for a nice upgradejust thought id see what yall thought.
Idk what it is but it sounds like a choo choo train lol good luck to you!
Sounds like a v8 sewing machine!
loose rod, spun bearing, check the oil for metal, coolant mixture, or just check if it has oil in it?
i had a broke piston shirt once that sounded like that...no not as bad as that...lol
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
Not sure if I have anything valid to add to this, but the Steamy water you noticed around the exhaust port is what mine was doing when I broke a spring and dropped a valve in #8. I think I posted a vid of it on here back in November. Link to that post is below.
http://www.ls1truck.com/forums/diagn...running-2.html
