93 Ford F-150 XLT 4x4...Transfer case problems
When i'm driving down the road in 4 wheel drive there is a pop every so often....i've already heard many solutions and tried a couple already. I already replaced the ujoint and checked out the front diff spider gears. I've boiled it down to the transfer case but I don't know what in the transfer case is causing the slip if that is indeed what it is. Any thoughts or advice?
- You may not post replies
- You may not edit your posts
