How are you guys getting to the brake light switch on the OBS for the TCC Ground?
I'm trying to finish up the wiring and I need to hook up the TCC Ground wire. It's the one that has 12v at all times then 0 volts when you hit the brakes. How are you guys getting to the brake switch? I can barely even see the thing? Is there somewhere else you're hooking into? My truck is a 95 w/t.
- You may not post replies
- You may not edit your posts
