Results 1 to 10 of 17
Thread: Aluminum driveshaft?
    The Garage
    I've been wanting to get rid of my factory two-piece driveshaft. That said, I've been looking on the "driveshaft specialist of texas" website. I'm considering one of their aluminum driveshafts both to reduce weight and go to a one-piece driveshaft. But how strong are these aluminum driveshafts and about how much power can they handle?
    im running the 5inch ....i have gone 150+mph
    The Garage
    Quote Originally Posted by CHEVROLADE View Post
    You have a RCSB, correct? I only ask because I have an extended cab and the driveshaft I'd need would be a bit longer. That shouldn't be a problem should it?
    Ponca City
    mines a rcsb. they talked me out of aluminum and into a steel one. its not light at all but they said id never break it.
    Slowest in Oklahoma...
    Nov 2011
    Arlington, Tx
    Aluminum is not a good idea of your planning on making power. I shredded mine, now I have a 2 piece 3.5 inch steel driveshaft on my crew cab.
    The Garage
    So, would a beefy one-piece steel driveshaft be a better idea for 600+ to the wheels?
    heres my aluminum 5inch next to oem lol
    Nov 2011
    Arlington, Tx
    Depending on the length you need, you might have to go with a two piece driveshaft.
    Ponca City
    Quote Originally Posted by jetmech View Post
    Call and talk to them. I spent an hour on the phone with em. I was hitting 400ish shots of juice and they wanted a steel one. It was cheaper for me. Boost is less violent on it so may not matter for you.
    Quote Originally Posted by LS3CC View Post
    thats more than likely what they will recomend
