Results 1 to 10 of 13
Thread: 4/6 Drop on the truck
    Sep 2010
    McPherson KS
    So I've been thinking that the truck needs to be removed from its 4x4 ride height, and decided that as soon as I have a decent amount of money I'm going with a DJM 4/6 drop (LCA's and a flip). I was doing some measuring and eyeballing today and couldn't help but notice that I may encounter some rubbing once the truck has been lowered. I'm just wondering if there is a creative way to trim back the splash guards up front that keeps water and other junk out of the engine compartment and body. Truck is sitting on Tahoe 20's right now with 275/55/20 tires.
    Spindles ride betta!
    Sep 2010
    McPherson KS
    I heard they had issues with turning on some trucks though. I'm looking for good ride and easy alignment. Not to mention a lack of rubbing.
    Mar 2007
    Newark, Delaware
    You won't get 4" of drop from just spindles...
    I have spindles on my truck(older belltech style) and I lost a lot of turning radius. I was planning on cutting my coils in the future for another 2" of drop, but now I'm considering just switching to DJM arms, as I've heard many good things about them.
    Paris, Texas
    i just put spindles on mine, A) you will only get 2" of drop, B)275/55/20 will not clear, C) i lost a lot of turning radius. i will try drop arms in the near future.
    Sep 2010
    McPherson KS
    Looks like next spring when I go for this I'll be swapping tires and control arms then. If any of you try them out before I get to it, tell me what you think of them.
    The DJM LCA's will get you about 3" of drop. If youre 2wd...which I thought I had remembered this truck was....you can cut the spring down a little bit to give you another 1/2 or full inch of added drop up front. For the rear you can do shackles and hangers or like you said a flip kit.
    Sep 2010
    McPherson KS
    It is 2wd, it just sits up like a 4x4. And I'm not trying for mega slammed with it, just looking to tuck the tops of the tires. Didn't realize the LCA's don't give the full drop though.
    Just realized you were wanting 4/6 not 3/4. Im sure that you could always get some drop springs and the control arms and that will make it work.
    Arizona/Utah
    Quote Originally Posted by Slammed96 View Post
    You are kinda worried about cost and what not. I think you are best of doing your drop a little bit at a time to see how you like it ride and appearance wise. Start with the cheapest and most simple which is rear shackles. Then add drop arms and rear hangers. See how you like it if you want more drop you can add some sort of front coils. I think you might be disappointed if you go all in on the first drop mods.
