Results 1 to 10 of 16
Thread: Which 6.0
    Which 6.0
    What truck/suv should I look to find a 6.0 out of ?
    which has the best intake heads etc ?
    Ill install a new cam only.
    Will be replacing my 5.3 in a crewcab 1500, I purchased a 5th wheel camper and it pulls ok but I want a little more
    thought of gearing down but I like when Im not pulling the tall gear.
    Look for an LQ9. Came in the SS and most of the gas HD trucks I believe.
    Ok, I hear about the Escalade and Denalis also, just didnt know If this had already been discussed , I m sure it has many times, If theres a link or another thread Id love to read it.
    Or are all 6.0's basically the same ?
    what year is your truck...a Ly6,L76 are badass as well with the L92 heads
    Arizona/Utah
    Quote Originally Posted by 1fastchevy View Post
    Nope LQ4 and LQ9 for the NBS and if you have a NNBS then a Ly6 or L76 are pretty dope too.
    Heads are the biggest improvement on the NNBS trucks and the LQ9 has higher compression and flattop pistons vs the LQ4.
    2008
    CrewCab , I wont be changing heads I just want to upgrade the cam drop it in and a tune.
    Jun 2004
    In a van down by the river- MD
    Any 6.0 you can get will be fine.. Your not going to notice much over less then a point of compression... They have the same heads, intake, unless your looking at the 07 up 6.0's Also depending what year truck it is going into, you want a 07 classic engine as they have the correct reluctor wheels, sensor location to make it plug and play for 07c trucks back to 99..
    John
    JOHN
    yes 08 up, i want plug and play.
    Ly6
    is the LY6 the variable timing engine ?
