Results 1 to 1 of 1
Thread: L33 camshaft,DBC bracket w/LS swap cable,30# injectors,95 factory radio,Gen.3 intake
    Spiro, Oklahoma
    All prices are "bets offer", I just need this stuff out of the way so as long as shipping and paypal are covered I'll let it go cheap. PM for quickest response.
    L33 camshaft from my 05 5.3L, has about 40-45k on it. Was soaked in oil and wrapped since its removal. I'm not sure of the specs but I know they are only a little more than an iron 5.3l. Would make a good replacement in a stock(ish) rebuild. $35 shipped.
    DBC bracket with cable. I had to elongate the holes to use it with an aftermarket throttle body but that won't affect anything. The cable with it comes with is the one guys use when swapping an LS engine into an older pickup. Cable PN is 15712337. SOLD
    These injectors came with a gen.IV intake I bought. I've never used them but the intake they came in was very clean. PN is 12580681. I believe they are rated around 30#, but please double check. SOLD
    Factory crank pulley from my 05 5.3L. Alt. pulley not included but if you need it also I'll throw it in. $25 shipped.
    Factory oil pump from same 5.3l 40-45k miles. Worked fine but replaced it with a Melling when I swapped cams. One of the pickup tube bolt holes was damaged but has been replaced with a threaded insert.
    Factory radio/cassette player fron my 95 Sierra, works and looks like new. $20 shipped.
    Gen3 truck intake with fuel rail and stock 2005 injectors (PN 25317628).The EGR hole has been plugged. No gaskets, fuel rail bolts, or sensors. $40 shipped. (No photo yet, if intersted I'll email one)
