Results 1 to 10 of 15
Thread: New Tb, or P&P
    Nov 2009
    Spring, TX
    Exclamation New Tb, or P&P
    Is it worth the money to buy a new throttle body, or should I just port and polish mine?
    Is it hard to P&P a throttle body, and will it make any difference?
    Jun 2010
    West Texas
    Well worth it, since its cheap and helps throttle response. This with a CAI helps smooth out the flow of air. Same as done with mandrel bent piping on the exhaust side. So its not to help pull in more air, but to help reduce turbulence.
    RUN WAT U BRUNG!!!!
    p&p is a nice easy upgrade that takes about a day depending on whats done.
    I wouldn't do it yourself if you haven't done it before...
    http://www.s2performance.net/gmtrucks.html
    Nov 2009
    Spring, TX
    Thank you, that was helpful.
    Nov 2009
    Spring, TX
    Have you had your Throttle body P&P
    Not yet, but when I spoke to my tuner about going to an 85mm aftermarket or having the stock P&P'd he said not to waste the money on a larger TB and just have it P&P'd.
    Nov 2009
    Spring, TX
    Did he say how much better the airflow would be?
    May 2011
    Corpus Christi, Texas
    im wanting to P&P my TB. ive never done it before... what exactly should i do? find someone in my area that can or buy one from the site listed above?
