Results 1 to 10 of 13
Thread: Can I run a Pro Charger with my cam?
    Jun 2010
    norman,ok
    Question Can I run a Pro Charger with my cam?
    I put a GMPP ASA cam in my '02 Silverado 5.3. Can I run a Pro Charger w/ this eng. or will I have to wait 'till I change over to the 454 stroker?
    Jun 2004
    In a van down by the river- MD
    Boost likes anything, just like nitrous.. Just a matter of what cam it likes more. Put the blower on and let it eat.. And do explain about this 454 stroker :/
    JOHN
    The Garage
    Punch your cam numbers into this thing:
    http://www.wallaceracing.com/overlap-calc.php
    If your value comes out "0" or negative then your cam should be fine for boost.
    Jan 2010
    Cedar Park
    Nice my cam have a value of -1 :-) 224/230 114lsa
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Jun 2010
    norman,ok
    Quote Originally Posted by jetmech View Post
    This link said my cam has an overlap of 11.00
    Jun 2010
    norman,ok
    http://www.erlperformance.com/gm-ls-...e-short-blocks
    I will pick one of these or maybe the SDPC 440 "the big bull" short blocks. also undecided between short / long block
    There's some others I'm looking at just want to do my reserch first and make sure I get the best one for me and for the $.
    The Garage
    Quote Originally Posted by mrfister View Post
    Personally, I wouldn't use that cam with boost if it has 11* of overlap, but that's just me. Cam usage, selection, and preference is a VERY divided topic so you will hear many different suggestions when it comes to cams. My cam specs are:
    580/580
    220/222
    114 LSA
    Just to give you an idea of what I believe is a decent boost cam. Hope this helps
    Jun 2010
    norman,ok
    That's what I thought about the cam, so I'll just wait 'til I stuff in the bigger cubes.
    Thanks.
    casey23 Guest
    camshaft
    Listen up cam expert ...... he has boost but it IS NOT a turbo....... So overlap is fine as long as he has enough blower/pulley to make boost .. My shop truck has a EPP blower cam... 232/240 115 600 600 or so.. And it makes over 620 on a mustang dyno on 10psi ....... 2004 LT Ex cab 2wd 5.7L 4l60 10psi and full weight truck..... 11.50-11.70 in the heat on pump gas and NO meth.... I think there are better cams then the ASA cam... but if you own it already then use it.... I like 4-6 degree split with a blower
    The Garage
    Quote Originally Posted by casey23 View Post
    Whoa, whoa buddy I was just throwing my opinion out there. I'm no expert Mr. camshaft Now go put that white thing of yours back together
