Well after 25k on the single front 76mm it finally tossed the #2 piston. So in good fashion my Dad just decided to go 402 instead of just adding pistons.... It an eagle 4340 crank, eagle 6.125 rods, wiseco pistons, 9.5:1 CR and had the heads PP while we were off. Not bad for a weekend build... I built the motor friday, put it in sat, and its off and running now, and sounds great, Im sure it will shell the 60e at the raceday.... but you never know... the truck is a 2006 Intimidator SS BTW
