Results 1 to 10 of 12
Thread: The cigarette lighters??
    Cedar Park, TX
    Why are there three cigarette lighter outlets, but only the one on the far right works? I plugged a multimeter into those three and of course the far right one got 12v, the other get nothing. WHY?!?!?!?!
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    So Cal
    fuse?
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    wichita falls, tx
    all 3 of mine work
    Intro Radicalli's
    Quote Originally Posted by banker099 View Post
    all 3 of mine work
    My 2010 only has one.
    Cedar Park, TX
    I checked the fuse, and it's all good. It's the same way with my buddy's truck. There is only one outlet you can plug a charger into or use the cigarette lighter in.
    R.I.P Blue '02
    '08 - 5.3
    I could see why one of them doesnt work because I noticed in my toyota the 12 volt outlet work but the cig lighter only works when using the lighter, but on my truck all 3 of em work I believe
    wichita falls, tx
    my 2010 only has one.
    99-02 ftw!!!
    Intro Radicalli's
    99-02 ftw!!!
    I have another in the bottom center console storage area I forgot about. I also have a USB...
    Round Rock, Texas
    Are they accessory power? Are the plugs controlled by the BCM?
    Jun 2010
    Did you test them with the key on? Could it be that the cig lighter is hot all the time, but the other two are only hot when the key is on?
