Results 1 to 9 of 9
Thread: on star fuse for superchip help please
    So Cal
    SEO ACCY i thought was the fuse to disable it and i removed it and the super hip still shows its active help please shoot text me call whatever 805-908-1421
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    So Cal
    24 views no one got any idea??
    come on guys i need help please
    Orono, ME
    Try fuse #45 under the hood. If not there, the owners manual should tell you where it is I believe.
    2012 Honda Civic Si - DD
    So Cal
    ill try thaf out thanks man! ya the owners manual listed it as special equipment option (SEO) i thought so i unpluged SEO ACCY and still nothing?but ill tfy your idea and let you know what happens
    So Cal
    how do i tell which pne is 45 they arent numberd not even under the electrical center lid
    So Cal
    I fixed it thanks man it was the SEO ACCY but it was the one under the hood i was pulling the one under neath the Steering column
    Orono, ME
    Glad you got it fixed man.
    I had to do this on my 08 to even get HPT to connect the first time. Luckily, the 2010 didn't need it to be done.
    So Cal
    ya i pulled the one under the hood and its fine now just gotta fix where i shift out at 1-2 wot cuz i dont think i pull any harder after 6k snd im shifting out at 6200 in drive so i need to fix that
