Results 1 to 2 of 2
Thread: Adaptive learning for GM trans
    Mar 2008
    hampton bays NEW YORK
    I found this interesting and thought some of u might too
    Original 355nation.net:
    Transmission Adaptive Functions
    The 4L60-E transmission utilizes a line pressure control system during upshifts to compensate for the normal wear of transmission components. By adjusting the line pressure, the PCM can maintain acceptable transmission shift times. This process is known as "adaptive learning" or "shift adapts" and is similar to the closed loop fuel control system used for the engine.
    In order for the powertrain control module (PCM) to perform a "shift adapt," it must first identify if an upshift is acceptable to analyze. For example, upshifts that occur during cycling of the A/C compressor or under extreme throttle changes could cause the PCM to incorrectly adjust line pressure. When an upshift is initiated, a number of contingencies, such as throttle position, transmission temperature, and vehicle speed, are checked in order to determine if the actual shift time is valid to compare to a calibrated desired shift time. If all the contingencies are met during the entire shift, then the shift is considered valid and the adapt function may be utilized if necessary.
    Once an adaptable shift is identified, the PCM compares the actual shift time to the desired shift time and calculates the difference between them. This difference is known as the shift error. The actual shift time is determined from the time that the PCM commands the shift to the start of the engine RPM drop initiated by the shift. If the actual shift time is longer than the calibrated desired shift time, a soft feel or slow engagement, then the PCM decreases current to the pressure control (PC) solenoid in order to increase line pressure for the next, same, upshift under identical conditions. If the actual shift time is shorter than the calibrated desired shift time, a firm engagement, then the PCM increases current to the PC solenoid in order to decrease line pressure for the next, same, upshift under identical conditions.
    The purpose of the adapt function is to automatically compensate the shift quality for the various vehicle shift control systems. It is a continuous process that will help to maintain optimal shift quality throughout the life of the vehicle.
    Clearing Transmission Adaptive Pressure (TAP)
    Transmission adaptive pressure (TAP) information is displayed and may be reset using a scan tool.
    The adapt function is a feature of the PCM that either adds or subtracts line pressure from a calibrated base line pressure in order to compensate for normal transmission wear. The TAP information is divided into 13 units, called cells. The cells are numbered 4 through 14. Each cell represents a given torque range. TAP cell 4 is the lowest adaptable torque range and TAP cell 14 is the highest adaptable torque range. It is normal for TAP cell values to display zero or negative numbers. This indicates that the PCM has adjusted line pressure at or below the calibrated base line pressure.
    Updating TAP information is a learning function of the PCM designed to maintain acceptable shift times.
    It is not recommended that TAP information be reset unless one of the following repairs has been made:
    Transmission overhaul or replacement
    Repair or replacement of an apply or release component, clutch, band, piston, servo
    Repair or replacement of a component or assembly which directly affects line pressure
    Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the PCM will need to relearn TAP values. Transmission performance may be affected as new TAPs are learned. Learning can only take place when the PCM has determined that an acceptable shift has occurred. The PCM must also relearn TAP values if it is replaced.
    Nov 2010
    safford, arizona
    It is important to remember most performance tunes limit this function as it would adversly affect the shift improvement a tune provides. Most consumers would rather not feel the transmission shift so the factory tends to allow relatively long shift times which we all know causes wear. You should also know that how you drive will also effect this function. If you are always above half throttle during shifts the pcm will increase line pressure as well as delay upshifts. I for one think the TAP is great for an off the lot truck however if you want to put a shift kit, corvette servo, larger spool valve, or any other trans mod to firm up your shifts, you can count on the pcm dropping off line pressure which can make your mods less effective. But like I said a good tune will correct the issues TAP creates.
