Results 1 to 10 of 10
Thread: po 157/ voltage guage inop
    Feb 2008
    IOWA
    my 03 silverado 5.3 has a po157 02 circuit low voltage b2 s2, and my voltage guage doesnt work.. any ideas?
    03 Silverado Extended Cab with 06 front end, Cai, Road Ripper 2000 Trans
    Feb 2010
    Central Texas
    sounds like you have two problems
    Feb 2008
    IOWA
    that i do and they are very seperate issues. bat and alt work fine, sounds like its the guage,, is there a cheap fix or can i put a remote guage in my pillar?
    Jun 2010
    baxley,ga
    step motors are bad about missing up in those clusters.thats prolly why ur gauge doesn't work.
    04 rcsb forged 347
    Feb 2010
    Central Texas
    Aftermarket gauge would probably be cheaper but what if you start having more troubles out of your cluster/ or what ever is causing your troubles
    Feb 2008
    IOWA
    are they easy to replace, never done one before
    Jun 2010
    baxley,ga
    yeah takes about 10 mins.when you buy a new 1 you have to take it to dealer so they can reprogram it.they have to take miles out of old cluster and put in the new one.unless you get a used one.the miles won't be same but some ppl don't care.if you get a used one make sure the numbers on back of cluster match yours cuz if it don't more than likely its different and won't work
    04 rcsb forged 347
