Results 1 to 10 of 18
Thread: Wheels and tires for the strip?
    Oct 2009
    Seattle, WA
    What kind of set-ups do you guys run when you are at the strip?
    I am looking into getting a set of D/Rs for the rear of my truck. I am wondering what I should do for the front cuz I have front Baer brakes which require me to run at least an 18in wheel. I have some 275/65/18 tires on denali wheels for the front, but idk if thats too tall of a diameter to match to a rear tire of 27 or 28 in tall.
    any thoughts?
    2003 GMC K1500 ECSB running an Iron 383 Stroker ......
    mine are in my garage check em out.
    Jun 2004
    In a van down by the river- MD
    Last time out, I used 28x11.5x16 ET streets, they didn't hook for shit. Next time out i will be using hoosiers.. If you are making alot of power i would rec a set of tires with a decent side wall, not a low pro style tire..
    JOHN
    Spring, Texas
    26x11.5x16 ET Streets on stock rims = 1.81 60ft.
    Jan 2010
    Cedar Park
    ASK purpleminivan about his 275/40/20 Nitto 555R's..... I wanna say he pulled down some low 60' times with those.
    Oct 2009
    Seattle, WA
    Quote Originally Posted by Sleaper View Post
    what kind of stock wheels did you use? It looks like those tires are supposed to be used with a 10 in wide rim? What kind of front wheels and tires did you use?
    Would it not be a good idea to run 32 in front tires and 26 through 28 in rears?
    Oct 2009
    Seattle, WA
    Quote Originally Posted by mangledgmc03 View Post
    I think my rig will prolly put down around 400 rwhp&tq. I am thinking 16in wheels in the back so yes the tires will have some meat on them.
    Nov 2009
    Tucson,AZ
    I just picked up a set of 28x11.5x16 MT ETs for 125$ used but alot of tread left! I got a set of 16 " stock 03 tahoe wheels that I got for 10$ so hopefully next time I hit the track I'll break into mid 13's
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    Gramercy
    im running M&H 275/55/16 28" on GM wheels. tire/wheel weigh in at 46lbs. my friend dead hooked on them with a 522rwhp 09 CCSB with a 5.3/6L80E, Pat G spec'd cam, Roush SC
    2008 GMC CCSB 6.2/6L80e swap
    Quote Originally Posted by chevyboy.520 View Post
    you shouldnt have a problem
    the 28x11.5 are really good for our trucks
