Results 1 to 8 of 8
Thread: transmision oil
    transmision oil
    hello again
    what is the best tranny oil!!! and why plz
    Chevy Silverado 2500HD 2007 Classic Body Ext.Cab / Procharger P1SC,linginfilter Cam GT2-3 with comp cam double springs,Walbro,60 pound injectors,E-fans,Breather,Hooker long-tube headers,magnaflow Muffler with customized 4'' pipe,TR6 spark plugs,MSD 8.5mm RED wires.
    Circle-d, Customized transmission kit (both on the way) and thank to Chris from Circle-D
    GA
    pretty sure if you got a 4l60e you need DEX IV. I know of castrol and supertech at walmart that makes it. Ive also heard that tranny fluid has to be so exact when it comes to the ingredients or additives (not sure what you call what its made of) that you cant go wrong with any brand.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    We use Pennzoil or whatever housebrand the auto store has, as long as it's DexIV, DexVI covers most of the trucks too.
    Never had an issue with just plain old convential oil. if you call around, most transmission shops will recommend that.
    I think it's more important to keep the trans running at a cool temp and change the oil often. I change mine about every 15-20K miles and it always looks great.
    I'm no expert on oils, but this is what works for us.
    Jun 2010
    West Texas
    Yeah tranny fluid is more for pressure than lubrication. Keeping the fluid clean and cool is the best thing to do than to look for higher dollar brands when the same thing is required.
    RUN WAT U BRUNG!!!!
    thanks all, i live in a very hot place last two weeks almost 56C , and the guy who rebuilt my tranny said that he have only the AC-Delco oil!!!!!! i dont know wht i hate this kind of oil!!!! and by the way my tranny is 4L80E on a classic silverado 2500hd
    Houston, TX
    What is the difference in the Dex IV and VI? I think I read the Dex VI gives results like using the Type F back in the days. Lets the tranny grab harder with limited slipage... Correct?
    2014 GMC Sierra Crew Cab
    -5.3
    -Gibson Exhaust
    Mar 2007
    Like Allen Said, Dex VI covers all the Trans, and is a great inprovement over pass Hydra oils.....is true the pressure more than lub, but also that means having a good lub that holds. Advantages of Dex VI includes a very important that is Antifoaming better than its predecesors.
    I use it on all Transmissions, and I have a 80e in my weekend warrior....Also I use Synthetic AC Delco in Daily Driven Trucks engines, and so far no complain. I use M1 in both toys (Truck and Maro)
    canada
    Im running the ams oil universal tranny oil its kinda pricy but It works really well and helps keep temps down
