What all is involved to swap an 08 ls2 into an 02 4.8? Is it direct? Or what problems could I run into?
Tia
Daniel
Tia
Daniel
the big one is going to be the reluctor. the ls2 is 58x, yours is 24x. this means you need to swap the entire computer, there may be an adapter or something on the market though...
U should be able 2 use ur 4.8 harness and ecu. but also do u have a complete takeout? e-fans? there are obviously a little more than just these things but need 2 know if its a complete takeout and i can answer a lil more...![]()
Well it's not going in mine. Someone I know is wanting to buy the ls2 tomorrow but I told him I didn't think it was a direct swap so I was wanting to double check
The engine He is buying is a block/crank/pistons/heads. Ext. No intake or accessories. And again it isn't going in my truck
There are a few things....the reluctor wheel needs to be changed from 58x to 24x. Or buy the electronic box. The Cam position sensor is on the front of the block and the wires will need to be changed... just swap A and C. The knock sensors will have to be relocated to the sides of the block. If the motor has DOD or VVT that will have to be removed. Also a possible lifter and tray swap and valley cover....
wut has 2 be changed if im putting an 05 lq4 into my 1994 GMC ecsb? just the major i know reluctor,crossmember moved back, motor mounts driveshaft, efans,yoke, and a nelson harness, wut am i missing? sorry 2 interupt ur thread SS..but wut he said is wut has 2 be done..go with his advice
