Results 1 to 1 of 1
Thread: TBSS intake, fuel rail & TB for sale
    Lafayette, La.
    For sale: 88mm ported intake off a 2006 Trailblazer SS 6.0 HO motor, fits cathederal port heads, comes with 34 lb injectors, fuel rail, LS3 90 mm throttle body & torque rush 8 pin to 6 pin TB adapter. $750 for the setup. PM me if you are interested. I will ship inside the 48 states the setup for that cost. I had this setup on a 5.3L LM7 but never could get it to run right. I think there was something in the tune not set just right and caused some problems on my truck. I also have a 88mm truck TB that I was using at first but it was shutting down at wot. I had ported the lip out of it. Don't know what was causing the shutdown, just swapped it for the LS3. $100 for it. The last pic is the LS3 body, the second to last one is the 88mm truck one that I ported the lip out of. The injectors have a different connector than the 2006 truck ones so I used my 31 lb ones and not these. If you are going to run this setup on a pickup, you might need to add an extra couple inches of rubber hose to the part that clamps on to the throttle body since the LS3 TB is set up for the intake hose to go to the drivers side and not the passengers side like the truck TB. I used a cheap clamp I found at Autozone and it sealed just fine. I have more pics if interested.
    2006 Chevy Silverado Crew Cab Z-71 5.3L, Custom Tune, Volant CAI, 4.10 gears, pacesetter LT's, Y-pipe, high flow cats, comp cam 202/212 500/507 cam, magnaflow muffler, msd coil packs, 1.8 rockers, 31lb injectors
