Thread: Hard start question
    Jan 2010
    Moore oklahoma
    Hard start question
    I don’t know if anyone has ever had this issue but when I try to start my truck after its been setting for a few hours it turns over several times before is starts and then will die. Bu will start just fine aster that. I have changed my filter and cleaned the mass air netter and also added fuel injector cleaner to the tank and still the same problem. Any in put would be well comedy. After it is running it is fine it is just the starting. It’s a 2001 5.3. Thank you in advance.
    2001 Silverado, work in progress. Add a vette servo and Nissan e-fans
    Aug 2005
    St. Anthony, Indiana
    start by checking fuel pressure.
    Jan 2010
    Moore oklahoma
    I checked it once before and it was around 50 something cant remember right off hand what should it be when you first turn the key?
    Aug 2005
    with the key on fp should be 55-62 psi, pressure should not drop more than 5 psi within 1 minute.
    My truck was doing about the samething, but it wouldnt start when it was first cranked then it would fire right up. Ended up changing the fuel pump now I touch the key and she fires up. Just my two cents
    Jan 2010
    Moore oklahoma
    That is what i am thinking it might be. The last time I checked the pressure it was like 50 to 52. Sounds like upgrade time.
