Thread: time for 4l80e
    Oolitic In
    time for 4l80e
    Well tonight lost the 4l60e launched hard in 4hi then nose dived and took off again and only has 1st now.... ftl lvl 5 is going in.... What all will i need to do this i know new stall fly wheel and the cross member anything else?
    VSS and wiring harness or you can do it yourself.
    heres a link to the wiring its simple took me like 5 mins.
    4L60E to 4L80E Wiring Swap - Page 3 - PerformanceTrucks.net Forums
    Cromwell, CT
    driveshafts, some kind of adapter for the t case, I think you can use the same flexplate.
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    im runnin my stock driveshaft stil but im 2wd
    2003 silverado x-cab stepside fully loaded..nelson tune..green CAI..160 thermostat..ls6 intake..pacesetter LT's..3"magnflow hi-flow's..one chamber flow dumped..4L60E PATC 1-2 servo 4th servo..trans go HD-2..ridn 24's...2" 4" drop..detroit tru trac an 4.10's setin n the shop waiting
    Quote Originally Posted by wstewart58 View Post
    stock drive shaft will have to be cut short about an inch, with the 80e yoke put on and a new U joint, you can get the U at the part store its a precision, part number 488
    Nov 2006
    Mesquite, TX
    need a flexplate of a 98 f-body, its a dished plate and will keep you from having to use the spacer
