where to buy transmission lines?
I think while installing my motor/trans I snagged 1 of my transmission lines and bent it where it goes into the transmission. I assume this because we never took the lines off the transmission/engine anytime, and we pulled the motor/trans from the silverado ourselves. So of course now it is leaking on the transmission inlet. The question is, where can I get them? Im guessing I can get them from GM, but I am unsure of the part number and cost. I tried searching on gmpartsdirect but that didnt help.
If it matters, they came from a 2002 silverado ext cab w/ 5.3/4L60E and a factory aux trans cooler.
Thanks!
- You may not post replies
- You may not edit your posts
