Since all you want to run is a 33 inch tire, just do the leveling kit with an add a leaf and longer shocks. Invest in some good quallity shocks since your cranking, they will help with the ride. The larger block will work but tends to leave you with a bit of axle wrap. The 3.73's will be fine with the 33's, but if you want to go bigger a re-gear would be best. Finally a custom tune would be best over the hand held type tuners.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
