Results 1 to 10 of 12
Thread: Magnacharger TVS1900 Truck Kit
Threaded View
    Apr 2005
    The Woodlands, TX
    This is a Magnacharger, TVS1900 Tuner Kit that I ran as a compound setup with a turbo on my 2001 GMC truck. The supercharger has apox 8000 miles on it and works perfectly. It is currently still on the truck but is coming off in the next 2 weeks or if someone buys it sooner.
    This is what you will get...
    *TVS1900 front drive/front inlet Compressor, intercooler and lower manifold
    *3.3" and 3.6" pulleys
    *Front bracket, tensioner assm, and belt
    *Valley pan cover needed for this blower
    *Fuel rails and adapter for return style fuel system
    *Custom made 2 core, over sized heat exchanger that is direct bolt in for 99-02 trucks
    *Magnacharger water pump and reservoir container.
    *Bracket I made to bolt throttle cable to supercharger
    Things you will NEED to complete the kit...
    *Fuel injector and fuel pump or Boost-A-Pump
    *4bolt 90mm TB
    *Air tube to from air box to TB
    *Tune
    *Installation instructions
    $4200 plus shipping and Paypal if used, OBO
    Some Pic...
    Heat exchanger
    Magnacharger valley pan
    01 ECSB 1/2 ton 4x4 6L GMC
    11.03@127
    KB Racing Borg Warner S475 turbocharged
    http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
