Results 1 to 10 of 17
Thread: Cant get my dipstick out . . .
    Buffalo or Rochester, New York
    Exclamation Cant get my dipstick out . . .
    So I started putting in my LPP Long tubes and ran into a problem removing the stock manifolds. The dipstick and its little bracket were keeping me from getting the manifold off and the header on. I could not get the dipstick out of the block, it refused to twist or wiggle out like the one on my '87 V20 did when I put long tubes on that truck. I ended up cutting off the dipstick tube with a big pair of wire cutters and crimping the end over to get the exhaust back on but now I have no dipstick Does anyone know how to get it out? Please help
    These new LS based motors sound absolutely AWESOME through open headers BTW!
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    You are serious? You cut it off?
    I can't get my dip stick in.
    Oh wait what were we talking about.
    Holy Crap you cut it out. Good luck with that. Might consider upgrading to a lokar .
    Round Rock, TX
    there is a bolt that holds that bracket to the head...15mm
    SugarGrove WV/Eubank KY
    take off the 15mm bolt, then if it doesnt come out, try getting under neath there and and using a long scredriver and peck it out.
    01CamaroZ28
    10.751 @ 124.26 mph with a 1.446 60ft
    ALL THRILLS NO FRILLS!!!!
    B&L Racing stg 1 heads 224/581 cam.
    06 silverado 6.0L VMAX LPP LT's, Volant CAI, Manaflow, NELSON TUNE.
    Southern WI
    That's cuz you need to think with your dipstick! haha sorry I couldn't resist, but yea take that bolt out and all will hopefully be well.
    Mike
    2000 RCSB
    Gotta peck on your stick to get it out. I think that's what I learned.
    Ok I mispoke when I starte this thread. I got the actual dip stick out, the skinny metal thing with the yellow handle. I cant get the dipstick tube out of the side of the block. I tried twisting it and wiggling and it wont come free from the block. I ended up kinking the tube trying to loosen it so I crimped it off. The LS engines are awesome but some of the stuff bolted to them is junk . . .
    Quote Originally Posted by kam2265 View Post
    Again, the dip stick tube is held in with a bolt. Did you take that bolt out? I hope so, if it is stuck them you probably use cheap oil
    take the bolt out. its in the side of the head. it is a 15mm.
    if you have to you can peck it out from below.
    01CamaroZ28
