Results 1 to 10 of 19
Thread: my 408 dyno
    Jul 2009
    kuwait
    my 408 dyno
    i dyoned my truck 2 days ago on md dyno which is less 13% than dynojet the number i had was 450hp 480tq soon i will upload the sheet soon i will dyno agine to tune the n20 i will put 200 shot , the prblem i`m haveing is the heat its over 40c so i cant increase the timeing alot the mode of my truck is :
    z71 2001
    -strocker 408 (11:* compression )
    -Chevy 6.0 Iron Block
    -Callies CompStar Crankshaft 4"
    -Diamond Pistons Flat 4.030 bore -2cc
    -Eagle Connecting Rods (6.125")
    -ARP Head Studs
    -Cometic head gasket
    -Patriot Performance GM LQ9 Stage III Cylinder Heads
    -Cam custom Magic Stick V.4 239/242, .649"/.609" 114 Lsa
    -SLP Performance Crank Under Drive Pulley
    -Pacesetter 3" QuickTrip Long Tube Headers + Y-pipe
    -92 Fast intake
    -92 Fast tb
    -afe air intake
    -COMP Cams Timing Chain and Gear Set, Double Roller, Bilet Steel Sprockets
    -4L60E tranny stock with a transgo kit+tranny fluid cooler
    -Ptc custom made torque converter 2600 stall
    -Dhm E-cutouts 3"
    -Msd 8.5mm spark wires
    -Msd Timing Twister
    -Msd Window RPM Activated Switch
    -NGK TR7
    -TnT EFI wet kit
    -SLP 160* T-Stat
    is my hp number ok or should i expect more ?
    Feb 2008
    Arizona
    welcome to the site! that's a nice looking truck and the numbers seems to be good.. is that rwhp??
    nice list of mods that you have.. maybe a higher rpm TC will help you out cause that's to small for that cam in my opinion..
    btw, I don't think your tranny will hold up with that kind of power..
    once again, welcome to the site.. enjoy! there are lotz of very experienced people around here that can help you out!
    Felix
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Jul 2009
    kuwait
    yes sir that a rwhp number.
    about the tranny thats right i`m very wory about it but swaping to 4l80 cost alot i will wait untel sumthing hapen to it then i will think to swap
    thanks for welcomeing me and i will try me best to help any one need my help
    yeah those are some good numbers I would think
    Crossett,Ar
    Look like great numbers to me man. When that Tranny goes out and you swap to a 80e I would look into a higher stall as well. That 2600 isnt going to get her off the line that well! Welcome to the site!
    Feb 2008
    Arizona
    I wonder how that pig would sound with a 110-112 LSA... do you have a vid to share man?
    Jul 2009
    kuwait
    Quote Originally Posted by Show&Go View Post
    you are right i will Replaced to sumthing biger
    Jul 2009
    kuwait
    Quote Originally Posted by White Devil View Post
    the ms4 gave me 80+hp i was very happy with it soon i will post my dyno vid and shet
    S.A. Texas
    Nice set up good luck with the Nitrous tune that thing will be a beast.
    Jul 2009
    kuwait
    this is the dyno run 631 rwhp with n20 shot
    YouTube - D 1
